Board index » Exterior » Glass and Gaskets
Anyone mod rear window so it opens?
Unread postby NobleTruths on Mon Sep 28, 2015 10:19 pm
As the title asks...
1967 Travco 270. Would love to be able to open the rear window over my bed. Anyone successful in doing such?
NobleTruths
Travco Model: 1967 Travco 270
Re: Anyone mod rear window so it opens?
Unread postby badbillybiker on Wed Sep 30, 2015 7:13 am
AFAIK...no one has... it is a kick out emergency fire escape window. A wire embedded in the gasket, that when pulled, cuts the gasket for an emergency egress. to mod this area, a thick and wide enough gasket would need to be acquired and an approprate sliding window to fit in the curved back. it is curved in 2 directions...and the only glass fixtures I know of are flat glass windows. best bet, leave alone, find smaller port holes or a slim long unit for fitting under the original. or get a unit (220,290 or 320 that has the flat back design which would more easily converted to you styling or modding. IMO FWIW
Unread postby NobleTruths on Wed Sep 30, 2015 7:51 am
I did not know about the wire. So cool! Odd that my original owner's manual says nothing about that. It just states to lay on the bed, and kick hard with both feet on one end of the window. Maybe mine does not have that wire.
Good thoughts about the complications of the task. Maybe I will design a way for the top to be hinged, and the bottom can be pushed open. Of course, the ladder in the back limits the amount it could open. I will have to think about this.
NobleTruths
Unread postby Acesneights on Sun Oct 04, 2015 9:06 pm
The 67 may not have that kick out window. Not sure. The widow is curved so making it open would be difficult I think.
Unread postby badbillybiker on Sun Oct 25, 2015 6:18 pm
remembering a t-top I had installed in a bronco...
If the rear window was removed and kind of glassed in to the size of an after market sun roof mod,
it would create, a window possibly to your criteria... fwiw
Unread postby Franknsr on Fri Oct 27, 2017 6:46 am
Is it possible to leave the window, seal and surrounding fiberglass intact and cut a couple inches just outside that perimeter? Of course you would have to build a pair of hinged frames with locks and a seal, then rivet the whole thing in place but it would give you a large opening. It would be a big job and definitely not for the faint of heart...
Franknsr
Travco Model: 270... I think
Unread postby badbillybiker on Fri Oct 27, 2017 7:12 am
Is this for air-flow ?
Both side rear windows open for cooling...
And the rear window...
It is designed to be kicked out/removed for an emergency exit...
FWIW
Return to Glass and Gaskets
Users browsing this forum: No registered users and 5 guests
