Board index » Exterior » Body, Paint Gelcoat specific
cracking/crazing treatment
Unread postby rjsdotorg on Wed Feb 14, 2018 7:00 pm
Now underway.
I belt sanded the crazed gelcoat (the whole stripe) with a 4" x 24" belt sander and 36 grit.
Rinsed and wiped dry.
Now applying 1.5oz glass cloth 18" wide around the whole rig. The stuff is thin as silk and still should prevent later crack print-through in the marine paint.
I thinned the resin ~5% and brushed from the centers of the cloth outward (it's been a while since doing glass).
I tried brushing the surface first then laying on the cloth and it didn't go well; just tack the cloth up with tape or a spritz of spray adhesive and brush it on top.
Not worried about wrinkles etc as they'll sand off and this is only about the fine cracks.
After spreading the resin, hard, the thickness is ~1mm.
2oz would be fine too. There is 3/4oz available but that would be crazy to work with.
You can see the ribs in the right light, and the whole thing is wavy, so absolute flatness is actually not desired.
rjsdotorg
Travco Model: 1972 270
Re: cracking/crazing treatment
Unread postby rjsdotorg on Wed Feb 14, 2018 7:03 pm
Also did the center joint delete, with 6oz glass5" wide.
Still needs fairing, as will the side stripe.
rjsdotorg
Unread postby rjsdotorg on Fri May 18, 2018 11:30 pm
A few updates:
rjsdotorg
Unread postby rjsdotorg on Fri May 18, 2018 11:31 pm
blue on
Pettit Bikini Blue
rjsdotorg
Unread postby rjsdotorg on Fri May 18, 2018 11:32 pm
tape off
rjsdotorg
Unread postby rjsdotorg on Fri May 18, 2018 11:34 pm
Raod -legal trim back on
new mirrors
vent doors cleaned up
rjsdotorg
Unread postby rjsdotorg on Fri May 18, 2018 11:37 pm
tail lights cleaned up pretty well too
rjsdotorg
Unread postby rjsdotorg on Fri May 18, 2018 11:46 pm
Suggestions to anyone attempting this:
  • use guide coat
  • use 18" blade and pull two layers of putty in cross directions
  • use guide coat, seriously. Or at least a gloss coat of some sort
  • look at it at all times of day in the sun, it will show defects with different sun angles
  • The Pettit Ex-Poxy is easy to use, follow directions, and use their high-build primer. I've painted a number of boats with it outdoors
  • use original 3M blue tape, or Frog tape
  • I spent 50 hours+ sanding and filling, and taping, actual paint is only about 3 including clean-up
  • practice on the A/C shroud
rjsdotorg
Unread postby 77Travco on Tue May 22, 2018 8:48 am
Wow, that's looking pretty good! You even put the Travco logo on the side! :D
Return to Body, Paint Gelcoat specific
