360 & 440 Cruise Control Manual
Please post up any Technical Manuals Documents or Drawings you have you have for other members.
Unread post by badbillybiker » Tue Mar 18, 2014 5:50 pm
Cruise Control Layout Manual\nHmm. Noticed nothing is here...\nAm fixing that right now...\nBTW, there is no #4 page...\nJust a poor labeling job...\nHTH 09/28/15\nBBB
Travco Model: 1974 270
Re: 360 & 440 Cruise Control Manual
Unread post by eescabar » Sun Sep 27, 2015 1:21 pm
Should there be something attached to this post. I am trying to determine if I still have all of the part to get my cruise control functioning. I have the controls, but after redoing all,of the steering column connections I found that what I think are the wires for cruise have been cut.
Travco Model: 1976 270
Unread post by RobC » Mon Sep 28, 2015 6:13 pm
mine was trashed top to bottom. I still have the parts but figured I would go with an aftermarket setup. My wiring was all there but the diaphragm was ripped and the "brain" was not working with regard to the speedo cable.
Unread post by KB2CRK » Mon Sep 28, 2015 6:21 pm
I am missing the diaphragm assembly. without it I have no clue if the rest of it works.
Unread post by badbillybiker » Wed Sep 30, 2015 7:19 am
Reposted this post, so it would show up on the current board index screen\nBBB
Return to “Technical Documents”
