Faulty Nuetral Safety Switch
Unread postby RobC on Wed Feb 01, 2017 7:06 pm
Turn of the key a few weeks ago to fire up the beast got the big NUTHIN.
Followed the manual decision tree and by a series of hot wires on the start relay, determined it was a the Neutral Safety switch. Ordered new one ( and a new starter relay) and swapped em both out. The PO had scabbed in a ground from the NSS terminal (ground) to the chassis and basically bypassed it.
reason for the post is: If your quick with your thumb- you can swap it out without draining the tranny fluid.
Only a mild geyser of pink fluid when I pulled it out with my left hand and put the new one in with my right hand.
Upon inspection the NSS switch plunger was stuck in the depressed position. I think the new NSS was $14 and the start relay was $12.
I need to do the shift-shaft seal but I think I need to drain the pain for that. Anybody done it from the top? My rig has no floor so I can get to it really easily. that seal is a bit more delicate though and I won't be able to manhandle it like the NSS
Re: Faulty Nuetral Safety Switch
Unread postby badbillybiker on Thu Feb 02, 2017 6:20 am
Interesting quick cure..Parts seem affordable to have spares.
Any part numbers for your fix????
Unread postby RobC on Fri Feb 03, 2017 2:52 pm
Posted parts numbers in parts section.
Return to Drivetrain
