gas tank clean and coat
Unread postby rjsdotorg on Sat May 19, 2018 12:02 am
had 1'8" of crud, and some rust.
Was a "new" tank, not original.
PO left it sitting for years with 15 gal of bad gas.
rjsdotorg
Travco Model: 1972 270
Re: gas tank clean and coat
Unread postby rjsdotorg on Sat May 19, 2018 12:04 am
power washed with 3000 psi
I had to cut a 3" hole on the other side of the baffle
rjsdotorg
Unread postby rjsdotorg on Sat May 19, 2018 12:05 am
coated with POR tank sealer
rjsdotorg
Unread postby rjsdotorg on Sat May 19, 2018 12:07 am
sender was full of crud and rust, but cleaned up well
Ohms changed dramatically, so it no longer will read 1/8 tank with 20 gallons
rjsdotorg
Return to Drivetrain
