Shifter Cable Help Please
Unread postby rfamlyslyds on Sat Jun 23, 2018 12:33 pm
Hi there -
Got a 1973 220 a few weeks ago and the shift cable is bent and was out of the vehicle at time of purchase.
Any info on ordering a similar part would be so appreciated as I seem to hit a roadblock at O'Reillys, Napa, PepBoys etc. Not sure what I'm doing wrong but 1973 Dodge doesn't give much insight as to the shift cable. I have a new cable that came with the vehicle but the ends are completely different etc so the previous owner gave up.
Thank you so much for anyone that can help.
Cheers
Jake Swanson
@rfamlyslyds
rfamlyslyds
Travco Model: 1973 220
Re: Shifter Cable Help Please
Unread postby raysimmons on Sun Jun 24, 2018 6:25 am
I have had a bit of trouble with finding dash parts until I found that there are similar dash parts in the A 100 vans from that era.(pre '70) I had trouble finding the speedo cable with the housing until we looked up (napa) the part as it applied to a '67 a 100 van and voila ! I think the automatic shifters were the same also so you might check that out, ray
raysimmons
Unread postby rfamlyslyds on Mon Jun 25, 2018 11:36 pm
Thank you Ray
I will run with that info and see what I can find out.
Jake
rfamlyslyds
Return to Drivetrain
