Overdrive options ...we need them
Travco Model: 1968 Travco 270
Re: Overdrive options ...we need them
Unread post by mabrandes » Tue Sep 13, 2016 11:26 am
77Travco wrote:
mabrandes wrote:I have a '68 270 w/ the 318 motor.... is swapping out the transmission to a 518 a relatively simple swap? Has anyone done it? I'm not a motor/gearhead so it isn't something I would do myself but would like to know if it is straightforward enough for someone that knows what they are doing to do it and would I gain anything by doing it.
\nIt depends... Which 318 do you have? A small block 318 or a Poly 318?
\n\nIt is a small block "LA" 318.
Matthew,\nWellsville, KS\n\n1968 Dodge Travco 270 | 2010 Teardrop | 1966 & 1968 Utopia Pan-O-Ramic TT's | 1950 Spartan Royal Mansion | 1969 Arisocrat LoLiner |1964 Barth TT
Unread post by 77Travco » Tue Sep 13, 2016 11:54 am
Yep, should bolt right up.
Unread post by KB2CRK » Tue Sep 13, 2016 12:29 pm
Gear vendors does have a Dodge Class A specific unit complete with new Parking brake assembly. It is almost 3500 dollars though.
Unread post by badbillybiker » Tue Sep 13, 2016 2:02 pm
Ouch!!! \nHope that includes installation.!!..\nHave to goto LA for it or more a \nlocally install?\nBBB
Unread post by KB2CRK » Tue Sep 13, 2016 2:12 pm
I did not look into it but I don't think that includes install or shortening of driveshaft.
Unread post by KB2CRK » Tue Sep 13, 2016 5:31 pm
Just verified by email. Installation not included. Driveshaft needs to be shortened about 14" and a new supplied yoke put on.
Return to “Drivetrain”
