Travco Driveshaft center support bearing
Unread post by Acesneights » Fri Jun 05, 2015 11:06 pm
aka Hangar bearing or carrier bearing. Mine is undoubtedly 40 yrs old and I think I should change it.\nAn exhaustive search came up with NAPA BRG HB88107B. That part # is a reboxed SKF HB88107B. According to SKF's catalog it should fit.\nI will post up when I get it and if it works.
Re: Travco Driveshaft center support bearing
Unread post by Acesneights » Fri Jun 05, 2015 11:07 pm
Also here is the SKF catalog.
Unread post by Acesneights » Fri Jun 05, 2015 11:09 pm
Rockauto has it for 51$+shipping
Unread post by highwaystar » Sun Jun 14, 2015 7:46 am
Thanks for putting up. That is on my list for next winter. Let us know if that number works.
Unread post by Acesneights » Mon Jun 29, 2015 8:34 pm
it looks to be correct.
Unread post by badbillybiker » Fri Dec 18, 2015 9:39 am
My 74 Travco mission continues... \nAcesneights, I am presuming that Carrier bearing number you posted was the correct unit?...(NAPA BRG H888107B)\nMy unit is once more going into the shop again, this time for the same,... a "pinging" driveshaft when going into park... \nWould like the numbers of the "u-joints", both front and rear if possible...presuming you replaced all of them once the shaft was out for the carrier bearing replacement...I stopped and looked before I went in to make sure I wasnt at a burger king by mistake! Counter parts employees do not instill confidence into me with their answers... \nTNX for any NFO...\nBBB
Unread post by Dave78Chieftain » Fri Dec 18, 2015 9:10 pm
Unread post by badbillybiker » Fri Dec 18, 2015 9:31 pm
TNX Dave for the numbers... I ripped the NFO and added it to my parts library...\nBBB
Unread post by Dave78Chieftain » Sat Dec 19, 2015 8:40 am
FYI - that NAPA number crosses to both Dodge P/N's 1881657 (69-73) and 3780272 (74 and later)
Unread post by 77Travco » Sun Dec 20, 2015 1:44 pm
badbillybiker wrote:I stopped and looked before I went in to make sure I wasnt at a burger king by mistake!
\nLOL... yep, old fashion parts guys are becoming a thing of the past it seems.
Return to “Drivetrain”
