Rear end dope
- Travco Model: 1969
Rear end dope
Hello! I have a 1969 track that I been restoring just finished all new brakes, wheel cylinders brake lines. I want to drain an replace the differential dope in the rear end can somebody tell me what I need to use ?
Re: Rear end dope
I'm sorry TRAVCO.
Re: Rear end dope
A standard 80w90 gear oli should be good.
Re: Rear end dope
Thanks so much for the info.
- Travco Model: 1966 Model 270
Re: Rear end dope
Verify if your diff is limited slip...mine was. If limited slip you need to pour in the additive with the 90w. Good luck.
