Rear end dope
Travco Model: 1969
Rear end dope
Unread post by Jessecommonman » Sat Aug 27, 2016 10:15 am
Hello! I have a 1969 track that I been restoring just finished all new brakes, wheel cylinders brake lines. I want to drain an replace the differential dope in the rear end can somebody tell me what I need to use ?
Travco Model: 1969
Re: Rear end dope
Unread post by Jessecommonman » Sat Aug 27, 2016 10:16 am
I'm sorry TRAVCO.
Re: Rear end dope
Unread post by KB2CRK » Sat Aug 27, 2016 3:05 pm
A standard 80w90 gear oli should be good.
Travco Model: 1969
Re: Rear end dope
Unread post by Jessecommonman » Sat Aug 27, 2016 4:23 pm
Thanks so much for the info.
Travco Model: 1966 Model 270
Re: Rear end dope
Unread post by Fellchase » Sun Aug 28, 2016 7:45 am
Verify if your diff is limited slip...mine was. If limited slip you need to pour in the additive with the 90w. Good luck.
Return to “Drivetrain”
