Updated master parts list
Post all known good updated part numbers.Please include manufacturer and source of info if possible.
Unread post by Acesneights » Wed Feb 15, 2017 9:15 pm
Courtesy of Bad Billy Biker... :mrgreen:\n\n\n\n\n\n Update: 02/06/2017 (BBB)\n\n\n\n Travco Parts List & Part Numbers:\n\n NFO is gleaned from various sources.\n\n Also my personal buying experiences.\n\n Be diligent while using this list.\n\n Information is deemed quite reliable.\n\n This listing is subject to corrections\n\n and updating and is constantly being\n\n revised with newly acquired or the\n\n latest correctable NFO. Keep in mind\n\n the very real possibility that some parts\n\n are no longer being made.\n\n NFO contributions from various TRAVCO owners\n\n helping this list is gratefully accepted\n\n and is now being shared among other owners.\n\n Help by doing your part in sharing.\n\n List helpful ??? Lemme' know...\n\n\n\n NOTE: This listing is done in ASCII TXT\n\n which is importable into the latest/almost\n\n any word processor for a printout.\n\n\n\n In a member's post, it is stated that the Original\n\n Travco glass is type "A3" and today's glass is "A2".\n\n The problem is that the Travco glass is THICKER\n\n and supposedly no longer available for replacement!\n\n\n\n\n\n Firing Order 440-3 1-8-4-3-6-5-7--2\n\n Oil Pressure (Nominal) 45 to 65 Pounds Pressure\n\n Spark Plug Gap .035 (Thousandths)\n\n Reluctor/Rotor Clearance .006 (Thousandths)\n\n Genset Gas Consumption (Est.avg. 4-6KW) 5.7 Gals per 8 hrs.\n\n Genset Gas Consumption (Est.avg. 4-6KW) 17.1 Gals per 24 hrs.\n\n Genset Gas Consumption (Est.avg. 4-6KW) .712 or 3/4 gal. per hour.\n\n\n\n Hydro-Vac NAPA--FEDERATED 51-8055\n\n Master Cylinder (1976) RAYBESTOS MC39012\n\n Master Cylinder Rebuild Kit (1976) RAYBESTOS MK899\n\n Master Cylinder (1976) BRAKEBEST 10-1583\n\n Master Cylinder (1974) n/a n/a\n\n Master Cylinder (1 3/4?) WAGNER GFF 70533\n\n Front Caliper Disc Rebuild Kit RAYBESTOS WK519\n\n Rear Wheel Cylinder Kit (M600) WAGNER F28661\n\n Rear Wheel Cylinder Kit (M500) WAGNER F86549\n\n Distributor Rotor (Slim) MASTERPRO (M14129) 2-3202\n\n Distributor Rotor (Wide) BWD Select D-147\n\n Distributor Cap MASTERPRO (M14006) 2-4201\n\n Spark Plugs (Correct) 440-3 AC DELCO (19157995) R45TS\n\n Spark Plugs (Optional) 440-3 AC DELCO R44TS\n\n Spark Plugs (Optional) 440-3 AC DELCO R42TS\n\n Spark Plugs (Optional) 440-3 CHAMPION J11Y\n\n Spark Plugs (Optional) 440-3 CHAMPION J13Y\n\n Spark Plug Wiring Kit 440-3 BWD CH 7866\n\n Water Pump (Verified) 12/05/14 NAPA (44-3) 58176\n\n Water Pump MOPAR (440-3) 3780196\n\n Water Pump HO (Interchanges w/Dodge 440-3) ----------------- ----\n\n ---------- Edelbrock Victor HO Series 8814\n\n Water Pump HO SUMMIT EDL 8814\n\n Water Pump (Poor replacement part) NAPA TFW 42040\n\n (Smaller impeller/no cross flange) ---- ---------\n\n Water Pump (1977 Travco) ADVANCE GMB 120-1200\n\n Water Pump / Dodge NAPA 3420225\n\n Fan/Alt Belts (2) DAYCO (440-3) 15450-0699\n\n Power Steering (1) DAYCO (440-3) 15475-1599\n\n No Air-Conditioning - Alt/PS belts same ----- ----------\n\n Power Steering (Orig? 1976) GATES Super HC 3Vx475\n\n Power Steer FEDERATED 15475FD\n\n Power Steer DAYCO 15475\n\n Power Steer GATES 7475\n\n Ballast Resistor (4 pin style) BWD RUE1\n\n Alternator GATES 7445 11A1130\n\n Ballast Resistor (2 pin style) BWD RU12\n\n Drive Shaft (Center) Carrier Bearing NAPA BRG HB88107B\n\n ECM (Electronic Control/Ignition Module) MASTERPRO 2-7037\n\n ECM Ignition Module (5 PIN) NAPA TP50SB\n\n Ignition Module Connector NAPA TPC51\n\n Front Disc Brake line (1" longer) NAPA-UNITED 36800\n\n Front Disc brake Line (220 & 270) NAPA 73521\n\n Front Wheel Octagon 3" Dia. outside ---- -----\n\n threaded grease cap 1 Ton 1933 thru 1978 MOPAR 564052\n\n Rear Brake (AE-1215-PF/15483/AE1215-FF) NAPA AE-402-R\n\n Rear Wheel Cylinder (2 cyl per wheel) NAPA 37279\n\n Rear Wheel Seal 1975 M500 NAPA 33136\n\n Hydro Boost 1976 & Up Replacement NAPA 52-9393\n\n Steering Box CARDONE 27-7501\n\n Steering Box Stub Shaft Seal Advance Auto POWERCRAFT 7095\n\n or ---------- ----\n\n Steering Box Stub Shaft Seal GATES 351310\n\n Steering Link ----- DS-881\n\n Chasis Drag Link (1976 M500) NAPA 272-4103\n\n Tie Rods (Right & Left) ----- Es2082R / Es2083L\n\n M500 5 Bolt Rotors (Kelsey-Hayes) K-H AR 8710\n\n M400 6 Bolt Rotors K-H AR 8712\n\n M600 8 Bolt Rotors K-H AR 8711\n\n M300 Rotors K-H AR 8712\n\n Windshield Gasket FORETRAVEL SC 1814\n\n Windshield Locking Bead FORETRAVEL SC 1819\n\n Wiper Motor (Use on either side) PRESTOLITE PME4001@12v\n\n Wiper Blades (TRICO) Using the "U" shaped\n\n adapter that comes with the blades TRICO 52-20\n\n Wiper Blades (Trico, latest number) TRICO 63 200\n\n Note: This is the arms & rubber ----- ------\n\n Wiper Blades (ANCO) Refills ANCO 53-20\n\n Rear Brake Drums Merit Truck Parts BUDD 75747\n\n Gas Cable (Same for 318/440) Balkamp or NAPA BK 6101407\n\n Gas Cable (Dod part number) DODGE 2960 213\n\n Coil 12v (Fits 440-3/318/360) NAPA 1C13\n\n Neoprene Valve Cover Gasket FELPRO VS13379\n\n Exhaust Gasket (Has a heat shield) FELPRO MS90425\n\n Oil NFO: 6.5-7 qts at Oil & Filter change ------ -------\n\n Oil Filter 1220800 or 122645\n\n Oil Filter UNOCAL PF-2A\n\n Fuel Pump 440 Dodge CARTER M6935\n\n Fuel Pump 440 Dodge AIRTEX 6935\n\n Fuel Pump (Mechanical to Block) CARTER CRT-P5494\n\n Fuel Pump Gasket (To Block?) 149-1445\n\n Fuel Filter (At Carb?) 149-1445\n\n Headlight,parking & TS (1 for ea. circuit) RELAY SIGNAL STAT #192\n\n Thermostat (Original Chrysler Part) 185Deg. CHRYSLER 3837609\n\n Thermostat STANT 13476\n\n Thermostat (180 deg) NADA THM532080\n\n Thermostat (Direct replacement) MR.GASKET MRG4367\n\n Thermostat (180 deg) ROBERTSHAW 370 180\n\n Recomends using a 7 PSI radiator cap...---------- -------\n\n Timing Chain 440/413 / Dodge NAPA 2205569\n\n Radiator Hose (1973 413 Formed Bottom) GATES 20933\n\n Radiator Hose (1975 440 (Cut to fit) NAPA NBH (Upper) 7634\n\n Radiator Hose (1975 440 NBH (Lower) 7711\n\n Heater valve Replacement MURRAY 277902\n\n Wiper Blade (Considered Heavy Duty) CARQUEST 752 200\n\n Motor Mount (Check First) NAPA 602 1115\n\n Dash Dimmer Sw. (headlight dimmer sw for a 1974 D300) take old unit with)\n\n Air Filter 440 FRAM CA347\n\n Air Filter 440 FRAM CA305\n\n Air Filter 440 FRAM CA324A\n\n Air Filter 440 Purolator A50093\n\n Air Filter 440 O'Reilly's Auto MicroGard MGA305\n\n NOTE: This MicroGard Air Filter is Made In Canada ------\n\n Air Filter 440 (2 5/8 Tall x 7/8 Thick x 12 3/4 Outside Diameter)\n\n Air Filter (Travco Factory Original) AC A354C\n\n Air Filter 140-1229\n\n Hydro-Vac Air Intake Filter Cartridge FRAM CA-2PL1\n\n Hydro-Vac Air Intake Filter Cartridge WIX xx-xxxx\n\n Headlight (BL - Bright Light) WAGNER H6024 EDL 8814\n\n Headlight PHILIPS H6024\n\n Headlight SYLVANIA H6024\n\n Headlight ( XV - Extra Bright ) SYLVANIA H6024XV\n\n Rear Engine support (Motor Mount) fits -------- -------\n\n 72 thru 79 R & M Series 4,5 & 600 Chasis MOPAR 3632984\n\n Hedman Street Headers for Motorhomes with ------- -------\n\n 318 & 360 Engines................... Hedman 79016\n\n Universal Brake Light Switch (Adjustable) NAPA SL169SB\n\n Onan 6.0 CCK Spark Plugs Champion xxxxxxx\n\n Onan 6.0 CCK Spark Plugs Autolite 216\n\n Camshaft Gear / Dodge NAPA 2780572\n\n CrankShaft Gear / Dodge NAPA 2705568\n\n Timing Chain / Dodge NAPA 2205569\n\n Hubcap Numbers -------- 20120\n\n Hubcap Nut Numbers -------- 10038\n\n Hubcap Clip Numbers -------- 10583\n\n Starter Relay (440) Standard SR102\n\n Neautral Safety Switch (727) Standard NS11T
Re: Updated master parts list
Unread post by KB2CRK » Thu Feb 16, 2017 8:03 pm
Front Brake Calipers\nRaybestos\nFRC-4041\nFRC-4042\n\nFront brake pads\nRaybestos\nPGD87M\n\nM500 Chassis 76
Unread post by badbillybiker » Fri Feb 17, 2017 4:14 am
TNX...Just added NFO to a coming updated listing...\nBBB
Unread post by KB2CRK » Tue Mar 21, 2017 7:25 pm
New master cylinders\nfor 75 and later with Hydroboost.\nCardone 13-1583\navailable through Summit Currently at less than $24.\nEverywhere else $45 and up.
Return to “Part Numbers”
