Part number list
Part number list
This is courtesy of Bad Billy Biker.\nSorry it took so long. Having some eye problems.\n\n\n Update: 11/15/2014 (BBB)\n\n\n\n Travco Parts List & Part Numbers:\n\n NFO gleaned from various sources.\n\n Also my personal buying experience.\n\n Be diligent while using this list.\n\n Information deemed quite reliable.\n\n This listing is subject to corrections\n\n and updating and is constantly being\n\n revised with newly acquired or the\n\n latest correctable NFO. Keep in mind\n\n the very real possibility of some parts\n\n are no longer being made.\n\n NFO contributions from TRAVCO owners\n\n helping this list is gratefully accepted\n\n and is being now shared among others.\n\n Help by doing your part in sharing.\n\n List helpful? Lemme' know...\n\n\n\n NOTE: This listing is done in ASCII TXT\n\n which is importable from a C=64 thru the\n\n latest word processor.\n\n\n\n\n\n\n\n Firing Order 440-3 1-8-4-3-6-5-7--2\n\n Oil Pressure (Nominal) 45 to 65 Pounds Pressure\n\n Spark Plug Gap .035 (Thousandths)\n\n Genset Gas Consumption (Est.avg. 4-6KW) 5.7 Gals per 8 hrs.\n\n Genset Gas Consumption (Est.avg. 4-6KW) 17.1 Gals per 24 hrs.\n\n\n\n Hydro-Vac NAPA--FEDERATED 51-8055\n\n Master Cylinder (1976) RAYBESTOS MC39012\n\n Master Cylinder Rebuild Kit (1976) RAYBESTOS MK899\n\n Master Cylinder (1976) BRAKEBEST 10-1583\n\n Master Cylinder (1974) n/a n/a\n\n Front Caliper Disc Rebuild Kit RAYBESTOS WK519\n\n Rear Wheel Cylinder Kit (M600) WAGNER F28661\n\n Rear Wheel Cylinder Kit (M500) WAGNER F86549\n\n Distributor Rotor MASTERPRO (M14129) 2-3202\n\n Distributor Cap MASTERPRO (M14006) 2-4201\n\n Spark Plugs (Correct) 440-3 AC DELCO (19157995) R45TS\n\n Spark Plugs (Optional) 440-3 AC DELCO R44TS\n\n Spark Plugs (Optional) 440-3 AC DELCO R42TS\n\n Spark Plugs (Optional) 440-3 CHAMPION J11Y\n\n Spark Plugs (Optional) 440-3 CHAMPION J13Y\n\n Water Pump NAPA (440-3) 58176\n\n Water Pump MOPAR (440-3) 3780196\n\n Water Pump HO (Interchanges w/Dodge 440-3) ----------------- ----\n\n ---------- Edelbrock Victor HO Series 8814\n\n Water Pump HO SUMMIT EDL 8814\n\n Water Pump (Poor replacement part) NAPA TFW 42040\n\n (Smaller impeller/no cross flange) ---- ---------\n\n Water Pump (1977 Travco) ADVANCE GMB 120-1200\n\n Fan/Alt Belts (2) DAYCO (440-3) 15450-0699\n\n Power Steering (1) DAYCO (440-3) 15475-1599\n\n No Air-Conditioning - Alt/PS belts same ----- ----------\n\n Power Steering (Orig? 1976) GATES Super HC 3Vx475\n\n Power Steer FEDERATED 15475FD\n\n Power Steer DAYCO 15475\n\n Power Steer GATES 7475\n\n Ballast Resistor (4 pin style) BWD RUE1\n\n Alternator GATES 7445 11A1130\n\n Ballast Resistor (2 pin style) BWD RU12\n\n ECM (Electronic Control/Ignition Module) MASTERPRO 2-7037\n\n ECM Ignition Module (5 PIN) NAPA TP50SB\n\n Ignition Module Connector NAPA TPC51\n\n Front Disc Brake line (1" longer) NAPA-UNITED 36800\n\n Front Disc brake Line (220 & 270) NAPA 73521\n\n Front Wheel Octagon 3" Dia. outside ---- -----\n\n threaded grease cap 1 Ton 1933 thru 1978 MOPAR 564052\n\n Rear Brake (AE-1215-PF/15483/AE1215-FF) NAPA AE-402-R\n\n Rear Wheel Cylinder (2 cyl wheel) NAPA 37279\n\n Steering Box CARDONE 27-7501\n\n Steering Box Stub Shaft Seal Advanced Auto-POWERCRAFT 7095\n\n or ---------- ----\n\n Steering Box Stub Shaft Seal GATES 351310\n\n Steering Link ----- DS-881\n\n Tie Rods (Right & Left) ----- Es2082R / Es2083L\n\n M500 5 Bolt Rotors (Kelsey-Hayes) K-H AR 8710\n\n M400 6 Bolt Rotors K-H AR 8712\n\n M600 8 Bolt Rotors K-H AR 8711\n\n M300 Rotors K-H AR 8712\n\n Windshield Gasket FORETRAVEL SC 1814\n\n Windshield Locking Bead FORETRAVEL SC 1819\n\n Wiper Motor (Use on either side) PRESTOLITE PME4001@12v\n\n Wiper Blades (TRICO) Using the "U" shaped\n\n adapter that comes with the blades TRICO 52-20\n\n Wiper Blades (ANCO) Refills ANCO 53-20\n\n Rear Brake Drums Merit Truck Parts BUDD 75747\n\n Gas Cable (Same for 318/440) Balkamp or NAPA BK 6101407\n\n Gas Cable (Dod part number) DODGE 2960 213\n\n Coil (Fits 440-3/318/360) NAPA 1C13\n\n Neoprene Valve Cover Gasket FELPRO VS13379\n\n Exhaust Gasket (Has a heat shield) FELPRO MS90425\n\n Oil NFO: 6.5-7 qts at Oil & Filter change ------ -------\n\n Fuel Pump (Manual/Engine) CARTER CRT-P5494\n\n Headlight,parking & TS (1 for ea. circuit) RELAY SIGNAL STAT #192\n\n Thermostat STANT 13476\n\n Thermostat (180 deg) NADA THM532080\n\n Thermostat (Direct replacement) MR.GASKET MRG4367\n\n Thermostat (180 deg) ROBERTSHAW 370 180\n\n Recomends using a 7 PSI radiator cap...---------- -------\n\n Radiator Hose (1973 413 Formed Bottom) GATES 20933\n\n Radiator Hose (1975 440 (Cut to fit) NAPA NBH (Upper) 7634\n\n Radiator Hose (1975 440 NBH (Lower) 7711\n\n Heater valve Replacement MURRAY 277902\n\n Wiper Blade (Considered Heavy Duty) CARQUEST 752 200\n\n Motor Mount (Check First) NAPA 602 1115\n\n Dash Dimmer Sw. (headlight dimmer sw for a 1974 D300) take old unit with)\n\n Air Filter 440 FRAM CA347\n\n Air Filter 440 FRAM CA305\n\n Air Filter 440 FRAM CA324A\n\n Air Filter 440 Purolator A50093\n\n Air Filter (Travco Factory Original) AC A354C\n\n Hydro-Vac Air Intake Filter Cartridge FRAM CA-2PL1\n\n Headlight ( BL - Bright Light) WAGNER H6024 EDL 8814\n\n Headlight PHILIPS H6024\n\n Headlight SYLVANIA H6024\n\n Headlight ( XV - Extra Bright ) SYLVANIA H6024XV\n\n Rear Engine support (Motor Mount) fits -------- -------\n\n 72 thru 79 R & M Series 4,5 & 600 Chasis MOPAR 3632984\n\n Hedman Street Headers for Motorhomes with ------- -------\n\n 318 & 360 Engines................... Hedman 79016
Re: Part number list
Thanks for posting... \nHope your eye problems are not too bad. I have had 5 eye surgeries in the past decade... including a retinal detachment!
I had issues to recently. Thought it was flash burn but Doc said I had something in it. Hurts like hell.
Motor Mounts-Anchor 2235 Seems to be valid part #. These appaerntly use the same motor mounts as a 1967 Dodge W300 383\nOrdered two today. Will verify .
