Found a supplier for Starter bracket
Discuss Onan, Kohler and whatever here. Also check out Smokstak.com
Unread post by KB2CRK » Thu Jan 07, 2016 2:15 pm
\nFound a starter bracket Thanks to Smokstak\nAnd applied GMC\nhttp://www.appliedgmc.com/level.itml/icOid/487
Re: Found a supplier for Starter bracket
Unread post by KB2CRK » Sat Jan 09, 2016 6:26 pm
Got the bracket today right before I left for work. It looks to be the right one just heavier duty. A little more meat to the cast. I will put it on and try it out Monday or Tuesday depending on how the Brake job goes.
Unread post by KB2CRK » Tue Jan 12, 2016 11:36 am
New and old brackets. New one is thicker.\nImage\nImage\nImage
Unread post by KB2CRK » Tue Jan 12, 2016 11:38 am
Fun to get to.\nImage\nImage\nImage
Unread post by KB2CRK » Tue Jan 12, 2016 12:49 pm
Generator is up and running. Exercising it right now. The old bracket seemed to allow starter movement when cranking. No movement at all with the new bracket.
Unread post by KB2CRK » Wed Jan 13, 2016 7:43 am
Part # for the bracket through Applied GMC is GM28-045-37.\nThe last good Onan # was 191-0929. It has been discontinued.
Unread post by 77Travco » Thu Jan 14, 2016 8:37 am
Good info to know. i hope I never have to do this! :D
Unread post by KB2CRK » Thu Jan 14, 2016 9:19 am
77Travco wrote:Good info to know. i hope I never have to do this! :D
\nIt is time consuming but not really difficult to do. You do need a puller and torque wrench for the flywheel. everything else is 1/4 20 bolts with 3/8" heads.
Return to “Generators”
