Board index » Generators
Discuss Onan, Kohler and whatever here. Also check out Smokstak.com
2, 6V batteries in series for an Onan?
Unread postby Dodgy71 on Thu Mar 17, 2016 7:13 pm
Was looking though the owners manual for my Onan Model 6.0 CCKB-3R (1971 Travco 270), and it says that the generator starting battery is actually 2, 6V batteries in series (to make 12V). Also, the battery hold down bracket appears like it is set up for 2, motorcycle type batteries, end to end. In fact, it doesn't look like an automotive 12V battery would even fit, due to limited space, side to side. Does this sound right?
What do others use for this vintage of Onan? I have heard that they require a pretty healthy battery (CCA wise).
Dodgy71
Travco Model: 1971 270
Re: 2, 6V batteries in series for an Onan?
Unread postby badbillybiker on Thu Mar 17, 2016 7:34 pm
here is a pic of my setup. 800cca automotive battery...
more than enough starting power... Be inovative...
Some things can be as is and at other times modded...
If it works................ this MY way...FWIW...
Unread postby Dodgy71 on Thu Mar 17, 2016 11:09 pm
Your set up looks almost the same as mine. I like your battery choice. Any idea what group type it is, as I would like to get one just like it?
Dodgy71
Unread postby badbillybiker on Fri Mar 18, 2016 8:38 am
sorry..... as my unit has been in a shop for the past 2 1/2 months
I cant help you at this time...
I had the battery sitting in the garage as a take out
from a van I had earlier trashed. If time is not important for this...
As soon as I get it back, I can check for you and post a pic and
nfo of this battery,.\. actually any large battery will work.
The onan is only a low compression TWO cylinder... HTH
Unread postby 77Travco on Fri Mar 18, 2016 10:00 am
I have a full size car battery in the space behind the generator. I thought that was the factory location for it? That's also where I keep my chock blocks.
Unread postby Dodgy71 on Fri Mar 18, 2016 1:31 pm
BBB: Sure, I can wait. Dare I ask what yours is in the shop for?
77: Does your generator compartment look like the one BBB showed in his pic? Mine looks like BBB's and I'm not too sure how I could fit a battery "behind" the generator. By "behind", do you mean inboard (toward the center of the MH, side to side), or toward the rear of the MH? In my compartment, there is only about an inch between the gen and the forward compartment wall, and similar to the rear compartment wall. Just curious.
Dodgy71
Unread postby 77Travco on Fri Mar 18, 2016 4:16 pm
Dodgy71 wrote:BBB: Sure, I can wait. Dare I ask what yours is in the shop for?
I'll take a picture and post it before the weekend is over.... if I forget remind me.
Unread postby 77Travco on Sat Mar 19, 2016 9:24 pm
Here are a few pics of my generator compartment. Notice how the battery is separated from the genset.
Unread postby Dodgy71 on Sun Mar 20, 2016 10:08 am
Thanks 77!
Definitely different than mine & BBB's.
Dodgy71
Unread postby badbillybiker on Sun Mar 20, 2016 1:42 pm
I think 77's genset is the alternator style with a oil filter and separate starter.
My 76 mahal had the battery mounted in the back like his, but the slide out & gen were gone!
FWIW: if the genset from my current was gone, a honda ue or eu would be the replacement...
no brainer in my house on that.
Return to Generators
