Board index » Travco Motor Homes » Travco 320/350
Re: our 320
Unread postby Dave78Chieftain on Tue Jun 02, 2015 6:51 pm
6 lug rims where used on the M600 chassis. You really need to locate your Dodge VIN number so it can be decoded to understand what your base chassis is. The VIN number plate is in the front radiator access area (driver side wall) on my 78 Winnebago. Not sure if that is the typical place on a TRAVCO or not.
Dave
Dave78Chieftain
Re: our 320
Unread postby 3rdranger on Tue Jun 02, 2015 8:36 pm
There is a Vin tag there. I'll check it out. Thank you
3rdranger
Travco Model: 1977 m320
Re: our 320
Unread postby 7d6 Travco on Wed Jun 03, 2015 9:58 pm
5-lug on 8" spread is stock in '76. Believe the rear end should be a Rockwell unit, not a Dana 70- somebody may know this for 100%
7d6 Travco
Travco Model: 320
Re: our 320
Unread postby 3rdranger on Wed Jul 08, 2015 2:04 am
New king pins and wheel bearing up front. All new tires, bearings and carrier out back. U joints in the driveline tomorrow. ........maybe a sweet test drive!
3rdranger
Re: our 320
Unread postby 77Travco on Wed Jul 08, 2015 8:12 am
I wish that I had a garage big enough to park my Travco in! :mrgreen:
Re: our 320
Unread postby 7d6 Travco on Wed Jul 08, 2015 4:16 pm
Me, too- I'd love to have my Travco nearby to work on. God only knows what it'd cost around here for a shop like that...
7d6 Travco
Travco Model: 320
Re: our 320
Unread postby 3rdranger on Wed Jul 08, 2015 7:32 pm
I love my shop! My wife thinks I spend to much time out there... :D
I'll let you know how the test drive goes
3rdranger
Re: our 320
Unread postby Acesneights on Wed Jul 08, 2015 8:19 pm
3rdranger wrote:New king pins and wheel bearing up front. All new tires, bearings and carrier out back. U joints in the driveline tomorrow. ........maybe a sweet test drive!
If you have a minute post up the part numbers to the u joints, carrier bearing etc you used in case they are different from the 270.
Re: our 320
Unread postby 3rdranger on Thu Jul 09, 2015 12:59 am
I did not replace the carrier bearings as they were in good shape. The u-joints were Neapco, part number 3-0056. To the beast for a drive tonight. Rear diff was nice and quiet. Front end felt much better!
3rdranger
Re: our 320
Unread postby Acesneights on Fri Jul 10, 2015 8:46 pm
Same number as a 270. Ok good to know. I'd bet the 270 Bearing is the same too.
Previous
Return to Travco 320/350
Users browsing this forum: No registered users and 0 guests
