Windshield wiper motors
Travco Model: 220
Unread post by gezundheit » Sun Dec 06, 2015 12:20 am
I want to pull the wiper motors and overhaul them.it looks like the dash top is the way into getting at them.am I on the\nRight track? Regards to all and merry Cristmas! Gezundheit.
Travco Model: 1967 Travco 270
Re: Windshield wiper motors
Unread post by NobleTruths » Sun Dec 06, 2015 12:06 pm
In my '68 270, I can access them by pulling the "wall" behind the pedals, and similar position on passenger side.
Travco Model: 220
Unread post by gezundheit » Sun Dec 06, 2015 2:26 pm
geeze,i don't think i could squeeze myself into a position behind the pedals and up to the motor.there has to be a better way.
Unread post by badbillybiker » Sun Dec 06, 2015 4:17 pm
don't know if you wanna' do it the way I removed my wiper motors...\nI took a sawZall and standing on a ladder in the front of my Travco...\nI just removed the wiper arms, then proceded to cut a large square\nin the fiberglass front at both of the motors making them an easy pull out for removal..\nRight now they are sitting on my garage floor and I can work on them anytime I want..\nyes,...still working...this Any help?\nReality....Has to be accessed from under the dash... or my way...\nPS: Overhaul?? If they ain't broke... don't...IMO\nBBB
Unread post by badbillybiker » Sun Dec 06, 2015 5:38 pm
thought a pic and a possible source might be of some help,,,\nI have other views of these wipers if wanted... HTH...\nThese posts now after leaving and returning no linger allow editing.. so...\nBBB
Travco Model: 220
Unread post by gezundheit » Sun Dec 06, 2015 6:41 pm
my balls went extinct years ago so,ill pass on cutting them out the front.my dash top looks to be held on by a few wood screws\nso I'm inclined to start the dig there.i'm forced to conclude that my alzheimer was arrested when i bought this travco and \nstarted to "restore"her.
Unread post by badbillybiker » Sun Dec 06, 2015 8:53 pm
HHmmm... is there a definite reason for a mission of that scope??? The block of wood present in the current pic is for spacing the motor due to the length of the shaft gearing and is a pain... My current unit has loose wipers but will let those dogs lie for a while...\nBBB
Unread post by Acesneights » Sun Dec 06, 2015 9:16 pm
they come out through the bottom of the dash. Drivers side IIRC was a PIA. I think I had to pull the instrument cluster. I didn't think they were even available. They make electric wiper conversion kits for old Mack trucks and Boats. I would think that could work. That pic you posted BBB sure looks like it though.
Travco Model: 220
Unread post by gezundheit » Mon Dec 07, 2015 7:49 pm
the passenger wiper only clears about 4inches and the driver side moves slowly even on high speed.so,since you guys are all in\nfor under dash removal i respectfully will remove the top and give a look.
Unread post by NobleTruths » Mon Dec 07, 2015 8:46 pm
I double checked. Passenger side is easy under the dash. Driver side pretty straight forward if you pull the instrument cluster.
Return to “Travco 220”
