What temp is everyone at
Re: What temp is everyone at
Unread post by Acesneights » Thu Apr 28, 2016 4:07 pm
Are you guys using actual temps measured by a thermometer or laser ? I would not trust the factory gauges.
Unread post by badbillybiker » Thu Apr 28, 2016 5:41 pm
Where would one use the laser/lazer for a true/accurate engine temp? \nI have a couple of no contact temp units I use\non trailer tires, rv tires and exhaust pipes on the motorcycles...\nHavent tried on the Travco yet.
Unread post by 77Travco » Fri Apr 29, 2016 10:48 pm
Acesneights wrote:Are you guys using actual temps measured by a thermometer or laser ? I would not trust the factory gauges.
\nI have a VDO manual temperature gauge installed on my dash. Before I installed it I checked it against a thermometer in a pot of water on my stove.
Unread post by highwaystar » Mon May 09, 2016 5:10 pm
My temp is based on a set of autometers I put in.
Return to “Engines”
