Board index » Main Discussion Areas » New Members Introductions
Welcome...
Stop here first and tell about yourselves...
Howdy - '72 270 on early 71 M375 chassis
Unread postby rjsdotorg on Sun Dec 24, 2017 3:11 pm
Picked it up recently, and currently working at "no brake pedal" problem.
Then fuel pump and electric frame pump for good measure.
Then maybe HEI conversion and a 160A alternator.
Had a 71 Chinook with the 318 years ago.
rjsdotorg
Travco Model: 1972 270
Re: Howdy - '72 270 on early 71 M375 chassis
Unread postby KB2CRK on Sun Dec 24, 2017 5:10 pm
Welcome to the Forum. No brake pedal can be a few things from a leak to bad boosters to misadjusted drum brakes.
Unread postby rjsdotorg on Sun Dec 24, 2017 5:32 pm
Thanks, first order I think is a power bleed and manual adjustment if needed.
I had added a pint of fluid and the "feel" improved, but still went to the floor, so I'll ask for a full bleed and we'll see.
I'd read that the booster can leak after sitting, and it sat for a year apparently.
rjsdotorg
Unread postby 77Travco on Tue Dec 26, 2017 11:58 am
Welcome!
Wheel cylinder seals are another culprit. See if there is any brake fluid leaking down the inside of a tire.
Unread postby rjsdotorg on Tue Dec 26, 2017 5:43 pm
Thanks!
Just ordered a new fuel pump pushrod as well http://store.440source.com/Fuel-Pump-Pu ... 00%2D1027/
PO replaced pump and not rod.
Also getting an electric pump for the rear rail.
rjsdotorg
Return to New Members Introductions
Users browsing this forum: No registered users and 17 guests
