1972 270 axle swap
- Travco Model: 1972 travco
1972 270 axle swap
I swapped the axles in my 270 and i thought i would put some info on it here. The donor was a 1978 georgie boy motorhome with a dodge chassis. The original plan was to swap the hubs with the 8 lug dana 70 but they did not fit the dana HD so swapped in the entire dana 70. The axle was a direct fit. Both axles had the same diameter 35 spline axles. The only difference i see is the axle tube diameter and some bearing diameters.\n
\n \nNext i swapped in the front axle but it wasn't a direct fit. I originally wanted to swap only the 8 lug hubs and disc brakes but the backing plate mounts were not the same so i swapped the entire axle. The leaf springs on the travco are 3"s wide and the leaf springs on the donor axle were 3.5 wide. I had to egg out the the axle center pin a 1/4" on each outer side to fit the travco spring width. The shocks on the donor axle mount to a plate on top of each lea spring. I swapped those plates onto the travco springs wich also helped take up the slack of the ubolt width. The axle then bolted right up.\n \n \n \nMy plans for next weekend are getting new brake lines made and im installing a hydro boost.You do not have the required permissions to view the files attached to this post.
Re: 1972 270 axle swap
Sweet!\nDid the steering linkage bolt right up?
I thought about doing this to my old one but with F550 Axles with rear disc.
The steering was identical to the old axle and bolted right up.
\n\nVery good to know!dirtydeno wrote:The steering was identical to the old axle and bolted right up.
Nope.
Were the axles same weight rating?
The later disk brake axles where usually a little higher of a rating.
The front axle looked almost the same so im guessing the rating is almost the same. The rear is less since its a 70 instead of the 70HD.
I think the front axle went from 3500 lb rating to 4000 lb rating. not a big difference. I think the spring width was larger on the later models
