Travco/Dodge add a turbo..
Doing a bit of research to put a turbo on my big Dodge engine. The very common Ford/Int. 7.3l engine is 444 cu in. Turbos are available. I have a Ford 7.3l with a turbo and the truck runs good. I am also gonna add some alcohol/water injection and experiment with adding LPG. Frank
Re: Travco/Dodge add a turbo..
Cool, A fellow diesel enthusiast. 7.3 is a good engine. I assume it's an IDI right ?\nI want to do a Cummins with an Allison but gotta find the right combo.
Dodge put Turbos on 440's in the late 70's. I found one a year back in a Foretraveler... which owned/bought out Travco.
Please post any/more info. I have been trying to make decisions about adding the turbo. Thanks, Frank
- Travco Model: Looking for 210
and on these, turbo lag wouldn't really be a concern... so remote mount wouldn't be so problematic... if you wanted to go that way. Even small amounts of boost could help a fair amount, without the need of dropping compression.
I just googled "Dodge 440 Turbo" and it comes up with some pictures and info.
