Power Converter
Travco Model: 1973 dodge 270
Power Converter
Unread post by lilivy » Thu May 31, 2018 4:51 pm
My 73 Travco had a power converter hooked up. I no longer need it. Is it worth anything or should I just scrap it?
Re: Power Converter
Unread post by KB2CRK » Thu May 31, 2018 5:33 pm
No longer need it? Did you do away with the 12v lighting and house batteries?
Travco Model: 67 270
Re: Power Converter
Unread post by ryemadd » Sat Jun 23, 2018 3:22 pm
im interested in it...how far are you from northern calif
Re: Power Converter
Unread post by lilivy » Fri Aug 17, 2018 10:24 am
KB2CRK wrote:No longer need it? Did you do away with the 12v lighting and house batteries?
\n\nI did not do away with it, my son did. This motor home is now all electric. Sorry it took me so long to respond, I have been ill for some time.
Re: Power Converter
Unread post by lilivy » Fri Aug 17, 2018 10:26 am
ryemadd wrote:im interested in it...how far are you from northern calif
\n\nSorry it took so long to reply, I have been ill for a good while. I am in Wisconsin and it is quite heavy. Just was curious to see if it was worth anything that is all.
Re: Power Converter
Unread post by Ryemaddamazin » Thu Jul 11, 2019 10:27 pm
Is the power converter still available ok
Re: Power Converter
Power convert still available
Return to “Travco 270”
