Shifter Cable Help Please
Transmissions, Rear Diff, etc.
Travco Model: 1973 220
Unread post by rfamlyslyds » Sat Jun 23, 2018 12:33 pm
Hi there - \n\nGot a 1973 220 a few weeks ago and the shift cable is bent and was out of the vehicle at time of purchase. \n\nAny info on ordering a similar part would be so appreciated as I seem to hit a roadblock at O'Reillys, Napa, PepBoys etc. Not sure what I'm doing wrong but 1973 Dodge doesn't give much insight as to the shift cable. I have a new cable that came with the vehicle but the ends are completely different etc so the previous owner gave up. \n\nThank you so much for anyone that can help. \n\nCheers\n\nJake Swanson\n@rfamlyslyds
Travco Model: dodge mahal,1970
Re: Shifter Cable Help Please
Unread post by raysimmons » Sun Jun 24, 2018 6:25 am
I have had a bit of trouble with finding dash parts until I found that there are similar dash parts in the A 100 vans from that era.(pre '70) I had trouble finding the speedo cable with the housing until we looked up (napa) the part as it applied to a '67 a 100 van and voila ! I think the automatic shifters were the same also so you might check that out, ray
Unread post by rfamlyslyds » Mon Jun 25, 2018 11:36 pm
Thank you Ray\nI will run with that info and see what I can find out. \nJake
Unread post by Ryemaddamazin » Fri Jul 12, 2019 6:24 am
My shifter is stuck in neutral any help please
My shifter is stuck in neutral been sitting for two decades help
Unread post by Woodsman » Fri Jul 12, 2019 11:53 am
Have you crawled underneath and tried to shift it on the tranny?
Return to “Drivetrain”
