battery tray wiring
Post here for living area electrical.
Zed
Travco Model: 270 Mahal
battery tray wiring
Unread post by Zed » Sat Apr 13, 2019 9:17 pm
There's been some hacks in my battery tray, trying to get it back to original so the house and starting battery are isolated. Can anyone provide a schematic or even a picture of their setup. Where would the isolator be located? 71 Mahal is what I'm working on. Thanks.
Re: battery tray wiring
Unread post by Woodsman » Sun Apr 14, 2019 7:45 am
I found these online. I also have a Dodge FSM for the 300 through 400 series chassis's in book form if you need me to look up something.
Dodge Class A 1973 Wiring Diagram.pdf
Travco Electrical.pdf
Zed
Unread post by Zed » Wed Apr 17, 2019 1:44 pm
So I traced some of the wires from the big red rotary switch. Positive 1 terminal goes to the positive of the started battery, Positive 2 goes to the accessory battery, and the negative wire goes to starter battery and is jumpered to the accessory battery so both really. This is correct right?
Unread post by Woodsman » Wed Apr 17, 2019 2:10 pm
Sounds right. You could just go straight to ground at each point.
Return to “Electrical”
