1977 travco 320 Engine Part Help
Unread post by tomdavis » Sun Oct 13, 2019 6:56 pm
What is the part circled in the photo? The rubber on mine is torn. The engine runs, but need to know if this is something I should replace sooner rather than later. Thanks!
Re: 1977 travco 320 Engine Part Help
Unread post by raydsimmons » Mon Oct 14, 2019 8:30 am
cruise control
Online
Unread post by KB2CRK » Thu Oct 17, 2019 6:40 am
Cruise control actuator. Vacuum diaphraghm pulls throttle when cruise is on. If your not using your cruise control it is not needed
Unread post by tomdavis » Fri Oct 25, 2019 9:44 am
Has anyone replaced the cruise control actuator with some thing newer, so we can use the cruise control??
Online
Unread post by KB2CRK » Fri Oct 25, 2019 11:17 am
I have an actuator off of a 97 Subaru Outback I was going to try after I got the TBI on it. The old style should still be available somewhere. I had the Subaru one laying around from an old parts car and the Cuise vacuum control unit is still intact on Nessie.
Unread post by tomdavis » Wed Oct 30, 2019 4:36 pm
What is the TBI, plz?
Online
Unread post by KB2CRK » Thu Oct 31, 2019 6:38 am
TBI is Throttle Body Fuel Injection.
The set up I have is from a company called FiTech.
Return to “Engines”
