NOS tail lights and back up lights installed
Unread post by KB2CRK » Tue Mar 01, 2016 5:08 pm
Just a couple pictures of the new lights on the rear. \nImage\nAll new lights\nImage\nOld on the right new on the left\nImage\nold on the right\nImage\nNew on the left
Re: NOS tail lights and back up lights installed
Unread post by 77Travco » Thu Mar 03, 2016 5:19 pm
Wish I had those "TRAVCO" letters on the back of mine!
Unread post by diskman » Fri Mar 04, 2016 2:09 pm
Wait a minute.. The inside lights are the reverse lights?? Mine has all 4 REDs across the back with some nasty issues to boot..
Unread post by KB2CRK » Fri Mar 04, 2016 3:41 pm
I have seen pictures of a few with the four red across the back. This place on ebay has been selling the fixtures. The reds have to be changed to dual filament wiring but that is not difficult.\nhttp://www.ebay.com/itm/Yankee-Lighting-Vintag ... xykmZTPGSx
Unread post by 77Travco » Tue Mar 08, 2016 3:27 pm
My insides are white (reverse).
Unread post by diskman » Tue Mar 08, 2016 3:35 pm
PO installed all 4 red across the back. All 4 are 1157 (high/low) but the inside lights are just wired to running lights. \n\nI *think* I solved my strange turn signal/brake light issues by ordering a new turn signal assembly. \n\nI will replace all the rears with new LED roundies and probably wire them all up as the same per side. Both rights will be brake/turn/running.\n\nSince someone butchered the wiring and deleted the reverse lights, I will probably add a relay setup and some nice bright LEDS under the rear bumper or wherever so I can actually SEE when I am backing up. I found the 75 wiring schematic and can find the reverse signal wire off the NSS. Will go from there.
