Do these turn into a bed?
- Travco Model: 1976 Travco 270
76 270, they look like they fold out, how?\n\n
Re: Do these turn into a bed?
Yes, yes they do. You may need to reach in and defeat the latching mechanism then lift the lower section as the whole thing moves towards the center as it goes flat. If you have a rear booth... that also turns into a bed and/or vise versa. The couch also lifts up and turns into bunkbeds, the top bed has seatbelt looking latches that go to the loop hooks in the ceiling.
Mine seems to have never had the top bunk installed. The ceiling hooks are there, but it looks like there never have been any hinges in the bulkhead.
The back of the couch has the hinges behind it.
Try pulling the back of the couch away and up from the wall. It will unfold and should have two seat belt straps that clip to the ceiling eye hooks.
There is no back.
Oh, ok... Well, here are a few pics of my couch to help you see what I am talking about in case you ever run across one.
I've been perusing your photos for a week and no dice, it just never existed on this particular RV
If the hooks are in the ceiling it had it at one time. Nessie never had one and does not have the hooks. I do have the back of a couch out of a 69 complete with hinges. I am going to try something with it when I get further into my interior remodel. If that does not work I will most likely let it go to another Travco home.
- Travco Model: 1976 270 Rear Bath
Greetings!!! Did you ever figure out how to get those seats to fold flat? I have the same seats in mine, and they slide forward and only go about half way flat. I cannot figure out how to get them to fold all the way down.
