It is currently Mon Oct 20, 2025 1:53 pm
\n\nOn mine, two bolts hold down the toilet, one on each side. Unscrew the nuts and disconnect the water line and the toilet comes up. After removing the toilet I had carpet under the the toilet flange. Usually 6 or so bolts holding that down but mine were rusted away. I tried to remove them and that’s how I broke my tank. If you can get yours out and it’s like mine, you should be able to unscrew the PVC extension (with the toilet flange) from the tank top of the tank (be careful).rjsdotorg wrote:So, how are the toilets held down?\nI want to remove that carpet....
